Vray does not render objects in my scene
edelsang
Message 1 of 17
edelsang
hi everyone.
I am new with 3ds max and I am rendering with vray but vray does not show my objects in render. Vray objects for example lights or plane are shown in render.
I do not figure out what problem is.
Accepted solutions (3)
Replies (16)
Message 2 of 17
kgokhangurbuz
Can you provide a screenshot?
Regards;
Message 3 of 17
edelsang
hocam koltuğu internetten indirdim. onuda görmüyo vray. kendim çiziyom onuda görmüyo.
I downloaded the sofa from internet but vray cannot render it as well..
Message 4 of 17
kgokhangurbuz
Try to flip normals of the model, if that does not work, please save your scene as 3ds max 2014 and share with me so i can take a closer look.
Regards;
Message 5 of 17
kgokhangurbuz
Hi;
After receiving your file as a private message, i simply rendered it as i received it, without any modifications;
I also noticed that adding Normals modifier does NOT change anything, since your objects normals are fine, so you can remove it.
here's the result on my screen:
My version of 3ds max is 2014, using V-Ray 3.30.05
I will simply want more screenshots from you, after the modifications below:
-Please assign a basic VRayMtl on your object, preferably with a texture (checker, maybe) preferably your whole scene and render, and share the result
-Please create a VRay Light > Type: Dome (place it anywhere on your scene and render, and share the result
-Please turn Global Illumination on, leave the parameters as default and render, and share the result
Regards;
Message 6 of 17
edelsang
It shows objects when I zoom out too much. whenever I look closest the objects I cannot see it on render.
I think my problem is zoom :S
Message 7 of 17
edelsang
you can see what I received while I zoom and zoom out
Message 8 of 17
kgokhangurbuz
Hi;
This is really strange, because i can render it at every level of zoom.
Can you try the following;
-Open a new scene of 3ds max
-Go to Customize > Units Setup Change Display unit scale to Metric, then go to System Unit Setup (button located at top), Adjust 1 Unit = 1.0 Cm's.
-Go to File > Import > Merge and choose your sofa model you have been working on
Re-Render.
If this does not work too, please also try rendering your object with Default Scanline renderer and / or Mental ray renderer (do not forget to change it's material to standard in this case, since VRayMtl currently assigned to this object might not be rendered by MR or Default Scanline R.
Regards;
Message 9 of 17
I have created a scene and when i try rendering it with vray for some reason the render output is odd can any one help me with this? The VRAY physical cam is not placed inside any object which means no object is obstructed with the camscreenshot 1.png
this is what i get when its rendered .........
Message 10 of 17
I am still new with 3d max and i have been having problems while rendering with v ray . please advice me how i can fix this. below shows and image of objects and render results. something somewhere is wrong..
Message 11 of 17
Alfred.DeFlaminis
Hello @Anonymous and welcome to the community,
Perhaps your license server is acting up.  You might want to contact Chaosgroup directly for this issue.
Best Regards,
Message 12 of 17
Hi edelsang
I was Created 3d File with Vray Render Setting , just put your model inside it and render it
its ready for lighting and camera and rendering setting
To Download 3d max file Here download
Hope this file help you and all other Designer
Best Regards,
Fadi Al-Qurainy
Senior 3D Artist
Message 13 of 17
You must turn off the Environment / Expose control "Mr photographic expose control" and put <No expose control> or Vray expose control
http://bimtobrilliant.com/the-easy-away-to-import-your-revit-model-into-3ds-max/
Message 14 of 17
Thanks a lot sir... You have save me stress of downloading toturials... Can you prepare for me Vray 3.30.05 3DS Max.. Please... Sir this is my email Icywongh@gmail.com Thanks
Message 15 of 17
Thanks a lot for this download... Please help me prepare for 3.30.05 Vray for exterior rendering for my building designs
Message 16 of 17
creationasif
change near clip and far clip value in camera attribute
Message 17 of 17
 see this image..
