Viewport Gray when opening 3ds Max
tomascastro2050
tomascastro2050
Hello, this is my first topic in the forum. I'm a bit overwhelmed because I opened 3ds Max 2025 as I always do and turns out the viewport shows in gray and cant see anything, even the above text where I'm supposed to change between viewport modes (wireframe, clay, shaded...) doesn't show. However I can model and create objects, even select them on the outliner, but can not see them, on new files and also on existing files. My graphic card is supposed to be working as usual, and also tried changing the display driver but nothing changes.
Anyone had the same problem?
Would be so thankful if someone helps!
A娘
seems you open max with null drive , change to dx11
use Change Graphics Mode in start menu or from viewports tab in preference settings dialog
MartinBeh
There is also a "Change Graphics Mode - 3ds Max 2025" shortcut in the Windows menu that allows you to change to a different viewport driver.
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
lauri_barnhart
Greetings, @tomascastro2050!
Thank you for posting your question in the community. Just checking in to see if either reply by A娘 or MartinBeh helped you resolve your question. If either of the replies helped you out, please consider clicking on the 'Accept Solution' button as this will help others with the same or similar question find a solution quicker. If you are still needing help, please post an update here so others in the community can jump in to offer assistance.
Best,
Lauri | Community Manager
