Viewport Going Blank (Max 2012)
syndicate5
Message 1 of 8
syndicate5
Using Nitrous Direct3D 9.0 with Nvidia GeForce GTX 970.
https://www.instagram.com/the_3rdkind
Replies (7)
Message 2 of 8
Chri688m
Might be an error caused by your current viewport settings have you tried to factory reset 3ds max? (not re-install)
Message 3 of 8
syndicate5
I havent tried to factory reset. Im actually not sure how to do that. Here's another pic. Sometimes the geometry will be there but then I get a whole bunch of info tags staying on the screen. This usually happens after Ive had Max open and sitting for a few hours.
Message 4 of 8
Chri688m
Erhhhhh... i have no clue why it displays those names... and i dont think factory reset will help : /
Sorry
_______________________________
One Does Not Simply Receive Kudos!
Message 5 of 8
Alfred.DeFlaminis
Hello @syndicate5,
Which OS are you running this on?  You might try to downgrade your drivers in the meanwhile or roll back to a previous version.   If that fails,  you could disable the tooltips in Customize>Prefs>General>Untick Enable Viewport Tooltips.
Another cause of disappearing objects could be an object that is infinitely far in the distance, you might check for that.
Best Regards,
Message 6 of 8
syndicate5
Thanks for the information, I’ll try that out. I would say that the tooltips are just a symptom of the problem, everything freezes up.
Message 7 of 8
Alfred.DeFlaminis
Hello @syndicate5,
I must have missed that in your posts that it freezes on you.  Which OS are you using?  Can you send your event viewer logs, please?
Best Regards,
Message 8 of 8
Alfred.DeFlaminis
Hello @syndicate5,
I just wanted to follow up here, any thoughts on my previous post? Thanks for the update!
Best Regards,
