V-ray not rendering imported megascans 3d object
I've recently installed Megascans along with Bridge& 3dsmax plugin to use their library, but it seems that v-ray does not render any materials from the 3d assets imported. The materials do appear in the 3dsmax realistic override ports& Arnold render engine, but here's how it  looks like in the  v-ray render port - middle one.
BenBisares
Autodesk Support
Autodesk Support
What is the material type on that object? I assume that the materials used on those objects are not compatible with V-Ray.
Ben Bisares
