I'm trying to select polygons, but for some reason it doesn't work, it's the same with edge
Solved by dmitriy.shpilevoy. Go to Solution.
That might happen if you applied Unwrap while in subobject selection mode of your EPoly without anything selected. Remove Unwrap modifier and apply it again while not in subobject.
