UVs automatically fitting into 0 to 1 space - how?
BenediZ
BenediZ
I wonder about, that Unwrap UVW with spherical mapping does not bring UVs into 0-1 space,
which is standard everywhere.
- Is there a setting to force it to do so with spherical mapping, like ist does with cubic mapping?
- is there an automatic setting, to fit UV's into 0 to 1 space?
BenBisares
Autodesk Support
Autodesk Support
You can use the "Pack UVs..." tool to get everything into the 0-1 space
Ben Bisares
lynn_zhang
Hello @BenediZ
Just checking to see if your problem has been solved. Have you tried the above suggestion from @BenBisares and did it work? If yes, please click on the "Accept as Solution" button in his reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
