UV Editor Default Behaviour
AirbornStudiosGmbH
AirbornStudiosGmbH
Hey guys,
just recently switched to the latest 3dsmax after using 2011 since... well forever
besides a few default behaviours that i could change, the UV editor drives me mad.
Is there a way to not replace the assigned Material with a default checker material on opening?
Just keep the applied material please, i have a bunch of pixel grid checker setups for various texture resolutions and always having to switch or reassigning materials is driving me crazy.
cheers
www.airborn-studios.com
we do art.
RobH2
I've never found a way to have it open like that by default. Maybe someone knows a setting. This would be a good thing to list in the "Ideas" forum. Maybe it will get implemented.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
spacefrog_
For me UV editor at least picks the last selected texture when i open it again( tested in Max 2024 briefly
). Is this not the case for you ?
Did not test this between 3ds max sessions, so i guess this is only consistent in the same 3ds max session
Or did i misunderstand the problem description?
Josef Wienerroither
Software Developer & 3d Artist Hybrid
AirbornStudiosGmbH
only within the session and only for an object its already setup. and only if you keep this modifier around. if you collapse. do things and open again, new modifier, settings are reset
if you have plenty of assets and work over various sessions you set this up again, and again, and again
we do art.
