URGENT : "Maximum Nested Error Dialog Depth Reached" when launching 3ds Max 2017
Message 1 of 8
Hello
i'm in an urgent situation , i really need to finish my project . but i keep facing this errpr when ever i start 3ds max 2017 . i followed all the ways . re installing etc ...
It's just i really need this to get fixed .
https://ibb.co/fk9mGB6
https://ibb.co/fCvFP7z
https://ibb.co/k30PXNH
https://ibb.co/KDzztRd
https://ibb.co/9yt97dv
https://ibb.co/qYR4Gmx
as you can see the errors ... any helps?
Replies (7)
Message 2 of 8
DanielCantin
Hi @Anonymous
Have you tried following this Autodesk Knowledge Network troubleshooting page solutions:   : https://knowledge.autodesk.com/support/3ds-max/troubleshooting/caas/sfdcarticles/sfdcarticles/3ds-Max-maximum-nested-error.html
Thanks for reaching out, please let us know if that solve or not your issue.
Daniel Cantin
QA Manager, 3ds Max, Maya
Entertainment Creation Products, ECP
Message 3 of 8
Hellp , yes i have tried that and still the same problem
Message 4 of 8
Also i uploaded a text file containing my MaxScriprt listener from 3dsmax 2017
https://gofile.io/?c=sMC3VZ
Message 5 of 8
DanielCantin
Hi @Anonymous
Is it possible you didn’t install dotNet or have an incorrect version installed? You might be missing mxsdotnet.dlx.
Here a old CGSociety post referring to a similar issue:  https://forums.cgsociety.org/t/startup-errors/993808
Please let us know if that solve or not your issue
Daniel Cantin
Message 6 of 8
Yes i have installed the latest version of it . still have this error .
Message 7 of 8
Any can help? please this is urgent i really need this to get fixed .
and as i saw there tons of people with the same problem maybe Autodesk can fix the problem sooner?
Message 8 of 8
Since there was NO HELP  . i was forced to DELETE the 3DSMAX
But in the future have some value for your users and fix your bugged products that thousands of people are facing this error .
each year you just add some bugs and release your products with tons of errors and problems and aks money for it .
It's so bad ... and disrespectful
