Announcements
update while creating
themaxxer
Message 1 of 17
themaxxer
I always use a rectangle to measure things from a plan... in 3ds max 2014 the dimension of the rectangle were updated while creating http://c2n.me/3apOhtj but in 2015 it doesn't http://c2n.me/3apNAQA.
it's very bad. can I change it somewhere?
thanks in advance
best regards
manuel
Replies (16)
Message 2 of 17
Stefan_L
Works fine here in 2015...
Stefan
i7-2600 @ 3,4GHz, 32GB Ram,
512+128GB SSDs + 2x500GB HD
GeForce GTX 980 Ti 6GB + GTX 980 4GB
latest Driver (almost always)
Win7ProX64 SP1
Message 3 of 17
themaxxer
hm... I have tried it on another machine, same problem... very strange
Message 4 of 17
csiri
I've got the same problem here in max 2014 since I installed max 2015 I belive. I'll let you know if I find a solution.
Message 5 of 17
csiri
Maybe having both 2014 and 2015 installed causes the problem?
Message 6 of 17
themaxxer
but why? I have installed both, yes...
Message 8 of 17
Steve_Curley
Works perfectly here, and I have 2012, 2013, 2014 and 2015 (SP3/EXT2) installed.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 9 of 17
themaxxer
really strange. Autodesk, any ideas?
thanks to all, problem still exists... 😞
Message 10 of 17
csiri
I found a "solution" to my problem. I clicked the "Adaptive Degradation" button on the bottom of the UI. So I turned off adaptive degradation, then turned it back on. I guess it's some kind of Autodesk black magic. Since then the viewport works as it used to. Try that, might help.
Message 11 of 17
themaxxer
great for you. 🙂 doesn't work here...
this is a really strange problem. I hate it. 🙂
Message 12 of 17
themaxxer
ok I got it... it's the new scene explorer. 😞 if you disable (close) it the th spinner updates as excepted.
now why is this happen?
best regards
themaxxer
Message 13 of 17
Steve_Curley
That might explain why it works here - I don't use the scene explorer (I reinstate the old SelectByName dialog). Lucky me - yes - but it helps narrow down the culprit.
Max 2016 (SP1/EXT1)
Message 14 of 17
Stefan_L
But even with scene explorer and layer explorer active the spinners update here...
Stefan
Win7ProX64 SP1
Message 15 of 17
themaxxer
I have also posted this in chaogroup forum and the problem seems to be random.
I hope to get a fix for it someday.
but maybe I have to wait for max 2016. 🙂
best regards
themaxxer
Message 16 of 17
themaxxer
I show it in a short movie... http://clip2net.com/s/3arktHI
best regards
themaxxer
Message 17 of 17
Stefan_L
I can reproduce it if the rectangle command is still active and the scene explorer has the focus.
If I click on the command panel once, the focus is on there and the spinners are updated.
Stefan
Win7ProX64 SP1
