Unsupported Controller
Hi !
When I try export .dae file with animation from Civil View in 3D Max. Software warning and errors that UNSUPPPORTED CONTROLLER  and I want to how fix this ??
Looking forward to your feedback and Thank You in advanced.
Duc,
my problemmy problem
Juanfranciscoangel
hi, have you been able to solve the problem?
Juan Francisco Angel
¿Te resultó útil esta publicación? No dudes en darle Me gusta a esta publicación.
¿Tu pregunta fue respondida exitosamente? Luego haga clic en el botón ACEPTAR SOLUCIÓN.
jon.bell
Thanks for your question! Before exporting, could you take a look at the Bake Point Cache information in the 3ds Max Help file and let us know if this works for you? If you're exporting to .fbx or .dae, you may have to collapse all the current vehicle animations to baked keyframes and/or point cache data first.
Please let us know if this helps!
Jon A. Bell
Senior Technical Support Specialist, 3ds Max
lynn_zhang
Hello @Anonymous ,
Just checking to see if your problem has been solved. Did you take a look at the article mentioned above and see if it helps? Let us know if you've had any success.
Lynn Zhang
