Unable to see vray lights in Vray LightSelect elements which comes through glass
In 3ds max when i set vray material's Refraction parameter's Affect channels to "Color only" Vray LightSelect render element does not show light which comes through glass. But when i set to "All channels" i can see the lights in Vray LightSelect render element which is coming through glass.
But the problem is that i can not set Refraction parameter's Affect channels to "All channels" in 3ds max because Vray Refraction render elements does not match to beauty pass with Linear Dodge (Add) blending mode in photoshop, it only matches when i set material's refraction parameter's Affect channels to "Color only".
more images
more images
Alfred.DeFlaminis
Hello @Anonymous,
Thank you for posting such detailed images and descriptions, but this would be a case for the Chaosgroup forums.  I do appreciate the community minded structure of your posts but there's not much that can be done about 3rd party plugin functionality.  I'm sure Vlado over at Chaosgroup would be interested in your images.
Best Regards,
