Unable to move around 3Ds Max
kowalik1224
Message 1 of 13
kowalik1224
Hi, I need help. Wanted to do some work on 3Ds Max 2020 student version today but, I couldn’t move around in the software. I tried on a different PC with 2019 version but I had no luck. I thought it was my mouse but scroll works as I can zoom in/out but doesn’t let me do anything else’s. anyone had that issue and fixed it ?
Replies (12)
Message 2 of 13
Diffus3d
Hello @kowalik1224 and welcome to the community,
Are you attempting to move via hotkey or camera settings?  What happens when you do try the hotkeys or camera settings?   Are you on a laptop?
Best Regards,
Message 3 of 13
kowalik1224
  1. Hi, I tried via hotkey and camera setting but nothing seems to work. Also, I did the same thing on PC and tablet which worked fine couple of days ago.
Message 4 of 13
Diffus3d
What kind of device are you trying to use this on now?
Best Regards,
Message 5 of 13
kowalik1224
I tried PC and Microsoft surface pro 4, it worked fine before
Message 6 of 13
Diffus3d
What kind of device are you trying to use it on, currently?
My guess is your graphics card is not supported.  Specs of the device?
Best Regards,
Message 7 of 13
kowalik1224
Tried this on my PC and tablet,  it worked fine couple of days ago. Also, tried on Microsoft surface pro 4 with intel core I5, HD graphics 520, 8GB of RAM,
Intel core i7 8700
GeForce 1060 6GB
16GB RAM
Message 8 of 13
Diffus3d
Which device is the device this thread is about?
Best Regards,
Message 9 of 13
kowalik1224
Both devices, on pc and tablet.
Message 10 of 13
Diffus3d
Just to be clear, you're using the hotkey Control + middle mouse button to move?  Control and Alt + MMB to rotate?
Are you using Maya control mode or something?
Do you have any weird peripherals plugged in?
What do you think it might be?
Not much to go on here.  Never heard of this problem in 20+ years.
Best Regards,
Message 11 of 13
kowalik1224
I have been using 3Ds Max since 2015, I never had that issue or even heard of it. I tried to move via camera settings and hotkeys + MMB. No using any control modes or settings, just standard 3Ds Max settings. Also, my mouse is Razer DeadAdder, checked all the drivers on graphics card and mouse, all up to date. So I have no idea what could be the problem. It all worked flawlessly before.
Message 12 of 13
Diffus3d
Ok, sorry just covering the bases.  Point taken.
OK, so then what do those two systems have in common?  Are they using the same keyboard?  Maybe the keyboard is bad?  Or maybe there's a mode select on the hardware level?  (Like a laptops function key?)
Maybe the middle mouse button is bound to a different key in windows?  (Happened with my RedDragon cheapo mouse.)  If you go into the razer settings and double check, is it bound to MMB?  Does the middle button work as normal in other apps?
Is something stealing focus from Max as you start to do a rotate or pan?  Does the screen blink when you start to rotate or pan?
Best Regards,
Message 13 of 13
jon.bell
Hi @kowalik1224 ,
Thanks for your question. Can you please try resetting your 3ds Max user preferences back to their default settings to see if this fixes the issue?
Please let us know if this helps, and we hope to hear from you soon!
Jon A. Bell
Senior Technical Support Specialist, 3ds Max
