Unable to Install, reinstall or unistall 3ds Max 2018
Hi, I have problems to install 3ds max 2018
I uninstalled because a problem apeared (mxdotNet.dlx) more windows open after that
I uninstalled and reinstalled, the same problem
Now I reinstalled, and the "installer" says 3ds max is installed, but inst true
 I tried a proof uninstall and deleted all main local folders to find a solution
the autodesk uninstaller program stops working
now I dont have 3ds max, but I cant reinstall, only features could be installed
If solutions are not avaliable, i will have to restart my pcCapture.PNGcant uninstall, not appearcant uninstall, not appearnot installednot installedno 3ds max installedno 3ds max installed 😞
brentscannell
hi @Anonymous, what happens when you click the top box for Max 2018 in the uninstall tool (to essentially remove those additional components), complete the uninstall, then try and reinstall 3ds Max 2018?
hello, if I uninstall all this components, that components will uninstall form pc, i tried to reinstall all autodesk products, every program could be reinstalled but no 3ds max.
the systems are not too complex, so I investigated and found a solution
uninstall all components
1.- search uninstall tool (autodesk)
2.- uninstall all 3ds max components
1.- PRES WIN+R
2.- TYPE regedit
3.- enter or OK
4.- go to the menu and find:
HKEY_LOCAL_MACHINE / SOFTWARE / Autodesk / 3ds max       (search above this folder, i deleted before)
delete ONLY (3ds max) folder with rigth click       (deleting other files, could be crash your programs)
reinstall normally
THAT S IT
