So when I opened up 3ds Max today the viewport background was completely white (with black grid) and I'm completely unable to change it. If I open up the Color panel in Customize User Interface the viewport color is set to the standard grey even though the background is white. I can change to whatever color I like in the panel but the viewport color will remain white no matter what I set it to. I can continue to work on my file without issues but the white color is definitely annoying.
Solved by info. Go to Solution.
I'm glad you found the solution so quickly. That was exactly what I suspected as I read your first post, mostly because I have run into this myself. Shaded views tend to default to showing the Environment Background.
Chris Medeck
