Unable to assign new shortcuts to 3ds Max 2024 Slate Material Editor
joachimbarrumX79N5
joachimbarrumX79N5
I'm unable to assign new shortcuts to the 2024 Slate material editor. Even if keyboard shortcut override is active the new key assigned will only affect the shortcuts outside the Material Editor. And if I assign keys that are not used they will not do anything.
PS! I tried assigning a shortcut for the "Show material in viewport" because this button is not currently working, but this action has never worked (in previous 3ds max versions as well) even if you have an option to assign a key to it in the Hotkey Editor.
This also applies to version 2024.1
This widget could not be displayed.
davidjohnson8888885
Observer
Observer
If you're experiencing difficulties assigning new shortcuts specifically within the Slate Material Editor in 3ds Max 2024, it could be a limitation or a bug within the software. Here are a few suggestions to try and resolve the issue:
1. Verify shortcut compatibility: Ensure that the keyboard shortcut you are trying to assign is not already assigned to another function within the Slate Material Editor. 3ds Max may prevent you from assigning the same shortcut to multiple commands.
2. Reset keyboard shortcuts: Resetting the keyboard shortcuts to their default settings might help resolve any conflicts or inconsistencies. You can do this by going to Customize > Customize User Interface > Keyboard tab > click on the Reset button. After resetting, try assigning the shortcuts again and see if the issue persists.
3. Check for updates or patches: Make sure you have the latest updates or patches installed for 3ds Max 2024. Autodesk often releases updates that address software bugs and known issues. Check the Autodesk website or the Autodesk Desktop App for any available updates.
4. Report the issue: If the problem persists even after trying the above steps, it's recommended to report the issue to Autodesk's support team or forums. Provide detailed information about the problem, including steps to reproduce it, and any error messages or unusual behaviors you encounter. This will help Autodesk investigate and potentially address the issue in future updates.
In the case of the "Show material in viewport" action not working, it could be a separate issue unrelated to shortcuts. Reporting it to Autodesk's support team or forums would also be beneficial in this case.
Regards.
David Johnson.
joachimbarrumX79N5
I believe its a bug within the material editor in max 2024. I have a fresh install, all other shortcuts are working as they should. and of course I have the latest update, as mentioned in my post.
giuseppe.schiralli
I reproduced the error in older versions of Max, specifically Max 2022.
When was the last time the override of the shortcuts worked?
-Giuseppe
Giuseppe Schiralli
3ds Max - QA Analyst>
joachimbarrumX79N5
I think it has not worked for multiple max versions actually. I have tried assigning ‘show textures on object’ in earlier versions without luck as well but didn’t report it because I could use the menu button and thought the keyboard shortcut meant some other command.  But this should be addressed, it would be nice to be able to make your own shortcuts in the slate material editor.
