TS Tools Unreal Engine Script File Paths
system-core
system-core
I don't know if you know about TS Tools a script by Tom Shannon for exporting meshes and copy pasting objects into unreal engine.  only issue is it has no method of pasting the paths to the meshes.
What I would like to do is modify the script to read a txt or csv.
I've got a file with an object name and path
Cylinder, /Game/Meshes/Cylinder
Sphere, /Game/Meshes/Sphere
Torus, /Game/Meshes/Torus
This %.% is the name of each object how can I change this to pass a name/path based on looking up an object name in a csv.
local defaultMeshPath = @"/Game/Export/%.%"
Here is the script
www.TomShannon3D.com
Exports models to FBX one at a time.
Each FBX file will be named after the Max Scene name
The models can be oriented to 0,0,0 on export (Rather than having them all stacked in MAX)
You can export the position of the models to the clipboard for easy placing in UE4 by pasting the clipboard contents then replacing the placeholder objects in UE4 with the correct objects.
Version 1.0 -	2014-07-22 : 	First version!
Version 1.1 -	2014-09-07 : 	Collision features and some useability fixes, renamed
								NEW: Allows users to explicitly set the export directory. This stays saved in the max file permanently and will be reloaded
								NEW: Users can reset the saved export path to use the default export path
								NEW: Exports UCX collision geometry! Just ensure your naming is correct, and the script will detect the apropriate UCX primitives for export. Note: they do NOT need to be selected or visible!
								Fixed: Export Window now identifies errors and offers some helpful tootips
								Fixed: Export path textfield identifies when no export path is available
								Fixed: Interface updates when the max file is loaded, saved or reset, showing the correct paths, etc.
								Fixed: Disabled Geometry-specific export options when the object position is being exported (To help notify the user as to what mode they are in)
								Fixed: Checks to see if export path is valid and asks user if they want to create the export path if it doesn't exist, rather than just making one
Version 1.1.1	2014-09-16 :	Fixed: Exporting objects now names objects correctly (Thanks, Maico G.!)
try (destroyDialog UE4_Export_FBX_Rollout) catch ()
local ExportType = "Geometry" --legacy variable
local ExportObjects = #()
local OriginalSelection = #()
--Strings for building things
t3d_Header =
"Begin Map
Begin Level
t3d_StaticMesh_Entry =
Begin Map
   Begin Level
      Begin Actor Class=StaticMeshActor Name=% Archetype=StaticMeshActor'/Script/Engine.Default__StaticMeshActor'
         Begin Object Class=StaticMeshComponent Name=StaticMeshComponent0 ObjName=StaticMeshComponent0 Archetype=StaticMeshComponent'/Script/Engine.Default__StaticMeshActor:StaticMeshComponent0'
         End Object
         Begin Object Name=StaticMeshComponent0
            StaticMesh=StaticMesh'/Game/Export/%.%'
            RelativeLocation=(X=%,Y=%,Z=%)
            RelativeScale3D=(X=%,Y=%,Z=%)
            RelativeRotation=(Pitch=%,Yaw=%,Roll=%)
         End Object
         StaticMeshComponent='StaticMeshComponent0'
         RootComponent='StaticMeshComponent0'
         ActorLabel=\"%\"
      End Actor
   End Level
Begin Surface
End Surface
End Map
t3d_Footer =
" End Level
Begin Surface
End Surface
End Map
global UE4_Export_FBX_Rollout = rollout UE4_Export_FBX_Rollout "UE4 FBX Exporter Version 1.1.1"
	group  "Export Mode"
		radioButtons UE4_ObjectType labels:#("Export Selected Objects to FBX Files","Copy Selected Object Transforms and Names to Clipboard") align:#left
	group "Export Options"
		checkbox UE4_UseGrid "Use user grid? (Grid must be named \"UE4_Grid\" to work.)" enabled:false checked:true
		checkbox UE4_MoveToOrigin "Move each object to 0,0,0?" enabled:true checked:true
		checkbox UE4_IncludeCollision "Include UCX Collision Shells?" across:2 checked:true
		hyperlink hl2 "For More Information Click Here" address:"https://docs.unrealengine.com/latest/INT/Engine/Content/FBX/StaticMeshes/index.html#collision" color:(color 0 0 255) visitedColor:(color 0 0 255)
		checkbox UE4_Dialog "Show FBX Export Dialog? (Will only be shown once per export)" checked:true
		label label1 "Export Path:" align:#left
		edittext UE4_ExportPath_Text readonly:true  width:360 align:#left across:3
		button UE4_SetExportPathButton "..."  height:17 width:17 offset:[174,0] tooltip:"Explicitly set the export path"
		button UE4_ClearExportPathButton "X"  height:17 width:17 offset:[60,0] tooltip:"Reset the export patht to be relative to this MAX scene file"
		button OpenExportPathButton "Open Export Path in Explorer"
	listbox UE4_Listbox "Objects to be Exported:" readonly:true height:20
	button doit "Export Selected Objects" width:220 height:50
	hyperlink hl1 "Help and Info" address:"http://www.tomshannon3d.com/2014/07/tstools-first-release-ue4-mass-fbx.html" align:#center color:(color 0 0 255) visitedColor:(color 0 0 255)
	local doGridTransform = false
	local exportObjects = #()
	local selnames = #()
	local ErrorArray = #()
	local exportPath = undefined
	local layerNames = #()
	local layerObjects = #()
	local packageName = "" --do i still need this?
	fn updateExportPath =
		-- If exportPath AND maxFilePath aren't set
		if maxfilepath == "" and ExportPath == undefined then
			UE4_ExportPath_Text.text = "Please save the scene or specify an export path explicitly."
		-- If exportPath has NOT been defined and the scene file HAS been saved, assume the export path
		if exportPath == undefined and maxfilepath != "" do
			exportPath = maxfilepath+@"export\"
			UE4_ExportPath_Text.text = exportPath
		--If there's an export path defined in the scene, use that instead
		SavedExportPath = (getAppData rootNode 77900)
		if (SavedExportPath != undefined) then
			exportPath = SavedExportPath
	--Ensure there's a valid export path before exporting. If it's not there, ask the user if they want to create the path or cancel
	--Returns true if the directory exists or is created
	--Returns false if the director doesn't exist and the user says NO
	fn checkExportPath exportPathName =
		if doesfileexist (exportPathName as String) == false then
			makeTheDir = queryBox (exportPathName as String +"Does not exist. Create this directory now?") title:“Export Directory Does Not Exist” beep:true
if makeTheDir == true then
makeDir exportPathName
return true
else return false
else return true
--Callback controls
	fn addCallbacks =
		callbacks.addScript #selectionSetChanged "UE4_Export_FBX_Rollout.updateList()" id:#UE4_Export_FBX_Rollout_Update
		callbacks.addScript #filePostOpen "UE4_Export_FBX_Rollout.updateList resetExportPath:true" id:#UE4_Export_FBX_Rollout_Update
		callbacks.addScript #systemPostNew "UE4_Export_FBX_Rollout.updateList resetExportPath:true" id:#UE4_Export_FBX_Rollout_Update
		callbacks.addScript #systemPostReset "UE4_Export_FBX_Rollout.updateList resetExportPath:true" id:#UE4_Export_FBX_Rollout_Update
		callbacks.addScript #filePostSave "UE4_Export_FBX_Rollout.updateList()" id:#UE4_Export_FBX_Rollout_Update
	fn removeCallbacks =
		callbacks.RemoveScripts id:#UE4_Export_FBX_Rollout_Update
	--return all collision shells matching the baseMesh's name
	fn findMatchingUCX baseMesh =
		local matchingUCX = (execute ("$'UCX_"+baseMesh.name as string+"'*")) as array
		if matchingUCX != undefined then
			return matchingUCX
		else return false
	--global updateList
	global updateList = fn updateList resetExportPath:false =
		if resetExportPath==true do
			exportpath = undefined
		--Actual objects to be exported!
		exportObjects = #()
		--Names, etc to populate the selection list. This veruable name is bad now because it handles some error strings as well!
		--run the export path function to ensure the path is as up to date as possible
		updateExportPath()
		--Check to see if there's a UE4_Grid object in the scene, if so set the options
		if $UE4_Grid == undefined then
			UE4_UseGrid.checked = false
			UE4_UseGrid.enabled = false
		else UE4_UseGrid.enabled = true
		--Make sure there's something in the selection
		theSelection = selection as array
		OriginalSelection = selection as Array
		ErrorArray = #()
		--Do some basic error checking:
		--Ensure something is selected
		if theSelection.count == 0 do
			append ErrorArray "    --Nothing Selected! "
			append ErrorArray "        Please select some meshes to export."
		--Ensure there's something selected that can be exported, also build the exportObjects array that's used for the actual export
		for obj in theSelection do
			if (superclassof obj == GeometryClass and classof obj != Targetobject and matchpattern obj.name pattern:"UCX_*" == false) do
				objName = obj.name
				append exportObjects obj
		if exportObjects.count == 0 and theSelection.count != 0 do
			append ErrorArray "    --No valid Geometry selected! "
			append ErrorArray "        Please select some non-UCX meshes to export."
		--Check the valididty of the export path
		if exportPath == undefined do
			append ErrorArray "    --No Export Path Defined! Please define an export path above."
			append ErrorArray "        Please define an export path above."
		if errorArray.count == 0 then
			if UE4_ObjectType.state == 1 then append selnames (exportPath) --display the export path in the window
			else append selnames ("To be copied to Clipboard:")
			if exportObjects.count == 0 then
				UE4_Listbox.items = #("No Valid Objects Selected! Only non-UCX geometry can be exported.")
				return true
			-- build the .fbx  list (THIS IS PURELY for display!)
			for obj in exportObjects do
				objName = obj.name
					if UE4_UseGrid.checked == false then tempString = "  "+objName+".fbx @ "+obj.pos as string
						else tempString = "  "+objName+".fbx @ "+(obj.pos-$UE4_Grid.pos) as string+" relative to UE4_Grid.pos"
					if UE4_MoveToOrigin.checked == true do tempString = "  "+objName+".fbx @ 0,0,0"
				if UE4_ObjectType.state == 2 then
					if UE4_UseGrid.checked == false then tempString = "  "+objName+" @ "+obj.pos as string
						else tempString = "  "+objName+" @ "+(obj.pos-$UE4_Grid.pos) as string+" relative to UE4_Grid.pos"
				append selnames tempString
				if UE4_IncludeCollision.checked == true and UE4_ObjectType.state == 1 do
					for UCX in (findMatchingUCX obj) do append selnames ("    "+UCX.name as string)
			if (selnames.count > 0 )then
				UE4_Listbox.items = selnames
		)-- END if selection.count != 0 then
		else
			append selnames ("There are errors; can't build the object list:" as string)
			join selnames ErrorArray
	)-- end function updateList
	on UE4_ObjectType changed newState do
		if Newstate == 1 then
			UE4_MoveToOrigin.enabled = true
			UE4_IncludeCollision.enabled = true
			UE4_Dialog.enabled = true
		else
			UE4_MoveToOrigin.enabled = false
			UE4_IncludeCollision.enabled = false
			UE4_Dialog.enabled = false
		updatelist()
	on UE4_Export_FBX_Rollout open do
		updateList()
		addCallbacks()
	on UE4_Export_FBX_Rollout close do
		removeCallbacks()
		UE4_Export_FBX_Rollout = null
	on UE4_SetExportPathButton pressed do
		--Open to a resonable location
		if (doesfileexist (exportPath as String)) then thePath = getSavepath initialDir:(exportPath)
		else thePath = getSavepath initialDir:(maxfilepath)
		print thePath
		--Once set, save the path to the scene's appdata
		if thePath != undefined then
			exportPath = thePath
			SetAppData rootNode 77900 exportPath
		updateList()
	on UE4_ClearExportPathButton pressed do
		deleteAppData rootNode 77900
		updateList()
	--Refresh the List/UI when otions are changed, etc.
	on UE4_UseGrid changed newState do updateList()
	on UE4_Dialog changed newState do updateList()
	on UE4_MoveToOrigin changed newState do updateList()
	on UE4_IncludeCollision changed newState do updateList()
	on OpenExportPathButton pressed do
		if exportPath != undefined then
			if (checkExportPath exportPath == true) then shellLaunch "explorer.exe" exportPath
		else
			messageBox "No export path is defined."
	--//* THIS IS THE BIG BUTTON PRESS FUCTIONALITY!!
	on doit pressed do
		updateList()
		if ErrorArray.count != 0 do
			ErrorMessage = ""
			for e in errorArray do append ErrorMessage (""+e as string)
messagebox ("Cannot export at this time:"+ ErrorMessage)
return false
--Getting the options here for easy reference
		doGridTransform = UE4_UseGrid.checked
		doOrigin = UE4_MoveToOrigin.checked
		dot3d = UE4_ObjectType.state == 2
		doGeom = UE4_ObjectType.state == 1
		doUCX = UE4_IncludeCollision.checked
		doDialog = UE4_Dialog.checked
		--Using the exportObjects generated by updateList to determine what to export
		--Probably don't need this anymore
		theSel = exportObjects
		--we need to 'pause' the callbacks in the script while we do this
		removeCallbacks()
		-- for speed
		max create mode
		--Here's where we create our selection arrays
		selectionArrays = #()
		-- Begin the t3d stringstream if we're doing that
		if (dot3d == true) do
			local t3dFile = stringstream ""
			format t3d_Header to:t3dFile
		--ensure there's a directory to export to
		if (doGeom == true) do makeDir exportPath all:true
		--This is so we only show the FBX window the first time
		firstObject = true
			objName = obj.name
			--select obj
			--Geometry/fbx
			if (doGeom == true) then
				if doUCX then select (append (findMatchingUCX obj) obj)
				else select obj
				--print ("SLKAJSLDKJALSKDJALKSJDLAKSJDLAKSJDLKAJSDLKJASLDKJASLDJK")
				local objectShift = [0,0,0] --to be able to shift the collision shells if needed
				local exportFileName = exportPath+@"\"+objName+@".fbx"
				local objTransform = copy obj.transform
				--Get the shift based on user options
				if (doGridTransform == true and $UE4_Grid != undefined) then
					objectShift = $UE4_Grid.pos
					if doOrigin == true do
						objectShift = obj.pos - $UE4_Grid.pos
				else if doOrigin == true then
				--move everything
				for o in selection do
					o.pos = o.pos - objectShift
				--Export selected!
				--Show the FBX dialog
				if firstObject == true and doDialog == true then
					exportFile exportFileName selectedOnly:true
				else
					exportFile exportFileName #noPrompt selectedOnly:true
				firstObject = false
				--Move everything back
					o.pos = o.pos + objectShift
			--.t3d --Now it just adds the text to the clipboard
			if (dot3d == true) then
				--Default transformations
				local OBJRot = (matrix3 1).rotationpart as eulerangles
				local OBJPos = [0,0,0]
				if (doGridTransform and $UE4_Grid != undefined) then
					OBJRot = obj.transform.rotationpart as eulerangles
					OBJPos = obj.pos - $UE4_Grid.pos
				else
					OBJPos = obj.pos
–Name=EditorCube7
--–RelativeLocation=(X=-2304.000000,Y=2047.999878,Z=298.000000)
--–RelativeScale3D=(X=4.000000,Y=2.000000,Z=0.250000)
--–RelativeRotation=(Pitch=0.000005,Yaw=180.000366,Roll=354.375000)
–ActorLabel=“EditorCube114”
if superclassof obj == GeometryClass do
format t3d_StaticMesh_Entry objName objName objName OBJPos.x (OBJPos.y*-1) OBJPos.z obj.scale.x obj.scale.y obj.scale.z (OBJRot.y*-1.0) (OBJRot.z*-1.0) OBJRot.x objName to:t3dFile
		--Close off the t3d file if it's being made
			format t3d_Footer to:t3dFile
			setClipBoardText  t3dFile
			free t3dfile
		select exportObjects
		updateList()
		addCallbacks()
	) --end on doit pressed do
) -- end rollout
createDialog UE4_Export_FBX_Rollout width:420
miauuuu
If I understand you correctly you want to:
- run the TS script
- pick a .csv file, lets say its content look this way:
- press the EXPORT button and the script has to:
-- ​ check if an object with the name "Cylinder" exists in the scene, and if it does exist, where the script has to export it ?
-- check if an object with the name "Sphere" exists in the scene, and if it does exist, where the script has to export it ?
check if an object with the name "Torus" exists in the scene, and if it does exist, where the script has to export it ?
Or the workflow must be different?
https://miauu-maxscript.com/
system-core
Not the export of meshes, it's the copy selected object transforms to clipboard. The script generates t3d code for each object such as StaticMesh=StaticMesh'/Game/Export/Cylinder.Cylinder'.
I would like to lookup a name get a path based on a scene object name it's processing and insert StaticMesh=StaticMesh'/INSERT/PATH/Cylinder.Cylinder'
When it's building the t3d for each scene object. The name must be in the clipboard if it could lookup Cylinder and paste its path /Game/Meshes/Cylinder
Lookup csv
StaticMesh=StaticMesh'/Game/Meshes/Cylinder.Cylinder'
StaticMesh=StaticMesh'/Game/Meshes/Sphere.Sphere'
StaticMesh=StaticMesh'/Game/Meshes/Torus.Torus'
Begin Map
Begin Level
Begin Map
   Begin Level
      Begin Actor Class=StaticMeshActor Name=Cylinder Archetype=StaticMeshActor'/Script/Engine.Default__StaticMeshActor'
         End Object
            RelativeLocation=(X=-38.163,Y=-27.0514,Z=0.0)
            RelativeScale3D=(X=1.0,Y=1.0,Z=1.0)
            RelativeRotation=(Pitch=0.0,Yaw=0.0,Roll=0.0)
         End Object
         ActorLabel="Cylinder"
      End Actor
   End Level
Begin Surface
End Surface
End Map
 End Level
Begin Surface
End Surface
End Map
miauuuu
Test this:
local defaultMeshPath = @"/Game/Export"
t3d_Header =
"Begin Map
Begin Level
Begin Map
   Begin Level
         End Object
            StaticMesh=StaticMesh'%.%'
         End Object
         ActorLabel=\"%\"
      End Actor
   End Level
Begin Surface
End Surface
End Map
t3d_Footer =
" End Level
Begin Surface
End Surface
End Map
	group  "Export Mode"
	button btn_getCSV "Get .csv file" width:220
return true
else return false
else return true
--Callback controls
	fn addCallbacks =
			return matchingUCX
		else return false
	--global updateList
		exportObjects = #()
		updateExportPath()
		ErrorArray = #()
				objName = obj.name
				return true
				objName = obj.name
		else
		else
		updatelist()
		updateList()
		addCallbacks()
		removeCallbacks()
		print thePath
		updateList()
		updateList()
		else
	on doit pressed do
		updateList()
			ErrorMessage = ""
			return false
		removeCallbacks()
		-- for speed
		max create mode
		firstObject = true
			objName = obj.name
			--select obj
			--Geometry/fbx
				else select obj
				--move everything
				--Export selected!
				else
				firstObject = false
				else
					OBJPos = obj.pos
				–Name=EditorCube7
				format t3d_StaticMesh_Entry objName defaultMeshPath objName OBJPos.x (OBJPos.y*-1) OBJPos.z obj.scale.x obj.scale.y obj.scale.z (OBJRot.y*-1.0) (OBJRot.z*-1.0) OBJRot.x objName to:t3dFile
			free t3dfile
		updateList()
		addCallbacks()
	local openFileRoll = dotNetObject "System.Windows.Forms.OpenFileDialog"
	on btn_getCSV pressed do
		result = openFileRoll.showDialog()
		result.ToString()
		if (result.Equals result.OK) do
			csvFilePath = (openFileRoll.fileNames)[1]
			fileExt = toLower (getFilenameType csvFilePath)
			if fileExt == ".csv" then
				format "Selected CSV: %\n" csvFilePath
				csvDataArr = (dotNetClass "System.IO.File").ReadAllLines csvFilePath
				removeCallbacks()
				max create mode
				firstObject = true
				for row in csvDataArr do
					fStrArr = filterString row ","
					objName = fStrArr[1]
					obj = getNodeByName objName exact:true
					if isValidNode obj then
						--select obj
						--Geometry/fbx
							else select obj
							--move everything
							--Export selected!
							else
							firstObject = false
							else
								OBJPos = obj.pos
							–Name=EditorCube7
							format t3d_StaticMesh_Entry objName fStrArr[2] objName OBJPos.x (OBJPos.y*-1) OBJPos.z obj.scale.x obj.scale.y obj.scale.z (OBJRot.y*-1.0) (OBJRot.z*-1.0) OBJRot.x objName to:t3dFile
							format "t3dFile: %\n" t3dFile
					else
						format "Can't find object with name %\n" fStrArr[1]
			else
				csvFilePath = undefined
				messagebox "Selected file is not a .CSV file." title:"ERROR !!!"
		openFileRoll.title = "Select Files"
		openFileRoll.Multiselect = true
		openFileRoll.Filter = "CSV (*.csv)|*.csv"
		openFileRoll.RestoreDirectory = true
) -- end rollout
Edit your csv file to look this way:
Cylinder,/Game/Meshes/Cylinder
Sphere,/Game/Meshes/Sphere
Torus,/Game/Meshes/Torus
Turn on the "Copy Selected Object Transforms and Names to Clipboard" and click the "Get CSV file" button. The content of the t3dFile will be printed in the listener.
The
defaultMeshPath
is added to the code, so when you press the "Export Selected Object" the script will use this path.
system-core
Thanks for this miauuuu
