Transform Gizmo Toggle hotkey removed
- Mute
- Permalink
- Report
With the hotkey reorganization in 3ds Max 2020, the very helpful hotkey for "Preferences > Gizmos > Transform Gizmos" was removed. This command is critical for translating spline Bezier tangent handles. Tangent handles are not objects nor sub-objects, so they cannot be selected. The Transform Gizmo gets in the way very commonly, especially when the spline is aligned with one of the world axes. The user cannot click on the tangent handle when the Transform Gizmo is superimposed over the handle.
"Preferences > Gizmos > Transform Gizmos" is the workaround. With Transform Gizmos disabled, and the Axis Constraint Tripod still visible, the user can choose Axis Constraints through the Toolbar or the F5 - F8 hotkeys. "Views > Show Tranform Gizmo" is useless because it also hides the Axis Constraint Tripod, making it difficult for the user to know what the current axis constraint is.
Please reinstate the hotkey for "Preferences > Gizmos > Transform Gizmos", which if I remember correctly, was <CTRL + SHIFT + X>. Also please change the items in the Views menu. There needs to be a menu based method to hide the Transform Gizmo but NOT hide the Axis Tripod.
Thank you
Aaron
