Strange issue-Can't isolate selection-scene for 3ds max 2016
562794142
562794142
Hi guys,
  I have a problem that I have never met,it is so strange,when I select an object and then isolate it,some of other objects should hide in this mode,but,they also shows in viewport,is that scene's problem?Dose anyone can help me to examine it,thanks in advance!
The scene can download here(2016 version)
https://1drv.ms/u/s!AlhTSsv8sTI2bJUekqvrpZ4kh20
RobH2
I looked at your file. It worked perfectly in Max 2019. I don't have 2016 anymore.
I took your file and tested it by isolating various objects and found no problems. I was thinking it might be a 'Group' issue or something. So, I 'ungrouped' everything and resaved it back to Max 2016.
Open this file and see if resaving it solves your problem.
https://drive.google.com/file/d/18LLhpwSF2WH-4bfzfQX5_ZjXGIs5psH4/view?usp=sharing
Edit: This is also something I do now and then when a file acts strange, open a new Max file with the same scale settings. Then 'Merge' the entire problematic file into this new file and save it. I've had this solve many odd issues in the past.
Rob Holmes
3ds Max (2023-2026), V-Ray 7, Ryzen 9 9950X3D Processor, DDR5 128MB, Gigabyte Aorus X870E Master motherboard, Sabrent Rocket NVMe Gen5 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
Hi, thanks for help,it's wried,I tested the file you sent me,in 2019 it works fine,but,I still cannot isolate some objects in 2016,I am not sure if it is a bug of 3ds max 2016,as you can see below:
2016:
So,do you have any idea?
RobH2
Is there a reason you are working in Max 2016? You said you tested it in Max 2019 and it was fine. Why not work in Max 2019.
Aside from that, maybe it is a bug in Max 2016, I can't say. I'm afraid I have nothing else to offer.
Maybe one of the Autodesk Monitors or Guru's will pick this up and help you. I'm not a software engineer so I'm out of ideas for you.
Rob Holmes
OK,thanks for your suggestion,I am going to switch to 2019!
