Hi all,
- select an object in one viewport, hit T to go to "top viewport" and suddenly you're in perspective view from the top. very irritating.
- random viewport zooms/movement (similar to above)
cheers,
I agree with uplink, I'm glad to see both cores slamming at 100 percent in mental ray, and who does not have a second computer on a KVM switch these days... I've got an extra one you can have 1.7 Ghz,.. I' don't think this a major issue, but a minor misunderstanding.
But then I am experiencing pretty good performance with Max 2009 running right now, so perhaps it is a matter of how hot your chips are! I'm running 2.8 Core Duo & 4 (3.2) Gigs of RAM for example, and browsing, typing, & even U-toobing are quite responsive.
I've done nothing with affinity or priority, so I'll try to keep an open mind.
-Shea
- select an object in one viewport, hit T to go to “top viewport” and suddenly you’re in perspective view from the top. very irritating.
Hi all,.....
- background system speed is still ridiculously low during rendering (and opening scenes) - typing text into this very window is taking ages.
the main irritation is this background system speed issue. it makes my system virtually unusable during rendering, which is a real hassle when I want to jump into photoshop during a render.....
cheers,
sorry but as i've mentioned a few times in this thread I have tried that already. that's what i used to do in 2008 and previous versions and it worked a charm - it has no effect in 2009 for me.
the really odd thing is that only certain people seem to have the issue at all in 2009.
if you do have this issue, can you post if you are on 64-bit? perhaps it's local only to 64-bit installs?
thanks,
Chris Medeck
