STEP Importter: Import Name Conflict
jens.diemer
jens.diemer
Why is there a "Import Name Conflict" dialog while importing a STEP file?!?
There is a object with the same name, ok. But there is no problem with objects with the same name. So why the dialog?
That slow down the import, if there are a few objects with same name 😞
Jens
https://github.com/jedie/3dsmax_bugs | https://github.com/jedie/3dsmax_patches
Florian.Coenen
Hello Jens,
FYI:
with the new 2016 version, there will be a "Rename all" option, that will improve the import speed, as you don`t have to click on "Skip" or "OK" for every object with the same name.
See here the screenshot of the import dialog:
Best Regards,
Florian Coenen
