I updated my Solidworks to the latest version 2018, but the 3ds Max can't import files anymore (sldprt or sldasm). Before the update the importation worked nice.
Could you help me please?
Solved by brentscannell. Go to Solution.
from the max 2019 help it can only import from 2001-2017 file format
when did solidworks 2018 come out?
DarrenP
Hi @Anonymous
Thanks for coming to the 3DS Max forums! Do you have a file that I can test on my side? Is there a warning that pops up on import, or does it just not see the file at all?
@DarrenP it looks like Solidworks 2018 released some time around September 26, 2017 because thats when the launch event was.
Talk to you soon 😄
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Hi @Anonymous
What version of 3ds Max are you using? 3ds Max 2019 should be supporting Solidworks 2018 imports.
@Anonymous
That's great to hear! If you have any further questions about the 3DS Max workflow feel free to post back in the forums 😄
Hagen Deloss
I am running into a similar issue to the one resolved here. I am attempting to Import 2019 SolidWorks files with Max 2019 and nothing is happening. I have an empty inspector when I do both mesh conversion on or off. What's interesting is that the 2018 version of these same files will import fine. Is this a known issue with SW 2019?
Using the tutorial files found here:
https://www.solidworks.com/sw/support/54117_ENU_HTML.htm?product=SOLIDWORKS%20CAD
Best,
Brent
Hi Brent,
Based on my notes, 3ds Max 2019.3 can only read up to Solidworks 2018 files.
3ds Max 2020+ can read Solidworks 2019
