Smoothing group information resets when applying Unwrap UVW modifier
I have a mesh that I need to create lightmaps for, however, when applying an unwrap UVW modifier and creating a second UV channel the smoothing groups reset.
I have tried resetting xform, applying a edit poly modifier, exporting and importing as obj/fbx into new scene. I have also applied individual uvw unwarp modifiers for each channel in the stack.
Any advice?
Josh
The smoothing groups of that model are a bit as quantum mechanics. You know it has smoothing groups but disappear as soon you try to look to them:
I have not been able to find a way to stabilize them, as they disappear as you try to access to faces in the editable poly.
It would be quite easy to rebuild the smoothing groups but I guess you want them not disappearing in the first place.
It is not the first time I have seen the instability of smoothing groups, sometimes disappearing the editing the meshes, but at least I was able to see at some point the smoothing groups numbers.
Finally after closing Max a couple of times I simply imported the file and added two modifiers unwrap and seems to work now. The second set as Channel 2. But don/t try to add an edit poly or smoothing groups will be lost. Not sure if this straightforward action solves anything. I include the file but I guess you could reproduce if you do the same, not edit of any kind apart of adding both unwrap. But who knows, perhaps when you open this Max file the smoothing groups are broken
https://www.dropbox.com/s/z73jo96s31wk04z/Desk.zip?dl=0
Thanks for the reply! Unfortunately, the file you linked is for a newer version of max so I cant open it. I have tried what you suggested, but the smoothing groups still reset. It looks like I just need to go ahead and manually recreate the smoothing groups!
This is Max 2014 that is as old as I can get
https://www.dropbox.com/s/od93ywi98i8mykj/Desk.max?dl=0
I would try anyway also to reproduce what I did, simply open your original file, add straightforward both unwrap and then change the second to channel 2, not adding edit poly or accessing to smoothing groups
Thanks again! That still didn't manage to fix it, maybe I need to reinstall max or something.
I did play around for a bit and managed to get it working by creating the 2nd uv channel on the existing UVW unwrap modifier, and not having to create a second one in the stack.
projinf3d
Another thing might be worth trying is converting the original bottom stack mesh to a 'Editable Poly' (opposed to 'Editable Mesh'). I also lost my smoothing groups applying the unwrap modifier when attempting to render to texture, though once converted the base mesh to Poly, reapplied the unwrap, the smoothing was intact.
projinf3d
Whoops my bad, disregard that with your scene as yours was Editable Poly to begin with :S... at least was the solution for my scene.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
