Skin Modifier Problem
I've got a problem with a skin modifier. I'm trying to rig a hand and when i'm adding bones to skin modifier weights are only 0 or 1. What can I do to to fix this issue ?
ads_royje
Hi erwinsokol,
this is usually due to vertices being set to Rigid.
If that is the case, it may be set for All or for the Selected vertices.
The All Rigid option is in : Advanced Parameters > [ ] Rigid Vertices (All)
The per (selected) vertices is in :  Parameters > Weight Properties > [ ] Rigid
I hope this can help! 🙂
The problem was in Voxel Solver Falloff, i changed falloff from 0,2 to 0,002 and everything works fine 🙂
ads_royje
ha! 🙂
Great!!
I did not mention that as usually this value of 0.2 is good.
Thanks for your reply!
Yes, but my scene is scale shifted, so that could cause the problem
ads_royje
Yes, you are right, the scale shift if most likely the reason!
That value serves that purpose! 🙂
