From what I have read here, there is no way to change the default values for tools such as Weld, Extrude, Inset etc.. Is that still true? I must use the symmetry modifier at least 50 times a day and would love to change the threshold from .039 to .003. Same with Weld, Inset etc...
Solved by zaluski. Go to Solution.
Solved by Alfred.DeFlaminis. Go to Solution.
Still looking for a solution for this. Im surprised no one has made a script for this if it cant be changed easy.
Thanks a bunch for this script, still trying to figure it out all the way but it definitely works good on the symmetry modifier. That there Sir just saved me a ton of clicking. 🙂 Do you have this installed? Just wondering if you have any problems with it?
Hello @chuck,
I'm glad @zaluski linked that, it's a cool script. It's a useful way of solving this issue. Thank you @zaluski, you're a rock star.
Another option is to make a button with the exact command and reassign the hotkey to the button which is a bit more legwork. I noticed we don't have an article about this up, so I've put in a request for one. You have to basically wrap it in a macroscript to pull it off, but I think the script here is probably more useful.
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
I look forward to read this article, thank you.
Hello @chuck,
I just wanted to follow up here, did the script suggested by @zaluski solve this issue for you? I just wanted to make sure! Thanks.
Best Regards,
Not completely, it works great on the symmetry modifier but I cannot get it to work for anything under editable poly or edit poly. Weld , extrude, inset all reset back to .039
@chuck; If for some reason this is not a good solution for you, I have another one:
Watch video from attachment.
Later you can edit values in the script in accordance with the needs by Edit Macro Script
Best Regards
This works and I thank so much, I set mine to a hot key,,, actually the same hot key I use to convert to editable poly.
You really got me thinking Ill tell ya. I dont know why I always forget about the MaxScript Listener. So what I did which even stream lines my work flow even more was I added a few more lines which converts to editable poly, selects vertex mode, then sets all the defaults in one go.
This is so sweet.
I have the best of both worlds now. All my modifiers and tools can be set with custom default values.
macros.run "Modifier Stack" "Convert_to_Poly"
macros.run "Modifier Stack" "SubObject_1"
$.weldThreshold = 0.00762
$.faceExtrudeHeight = 0.2794
$.insetAmount = 0.254
