I had this problem while installing SQL Server 2019 express instance. Installation error suggested I install Microsoft Visual C++ 2017 Redistributable (x64). However, even after installing the 2017 redistributable, the problem persisted. However, the redistributability provided by the link in this answer titled "Microsoft Visual C++ 2015-2019 Redistributable (x64)" actually solved my problem. The version number of the second version is 14.28.29325 while that of the old version (2017) is 14.16.27033
Alternatively, you can try the following basic guide:
1, Uninstall and clean completely. It is recommended to use application removal software such as ccleaner. Restart the computer.
2, Install SQL2019 separately, restart the computer. Make sure the installation is in administrator mode.
3, Reinstall, do not change the installation package, the installation packages in the world are the same. Make sure the installation is in administrator mode.
________________________________________________________________________________
Architect at Phuong Vinh Interior Design Company, chuyen thiết kế nhà Hải Phòng và xây nhà trọn gói Hải Phòng
