- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Main idea:
Hi is it posible to create a feature like this in 3ds max...
Steps:
-Bottom left window shows only the highlighted vertices, the ones it show
they will highlighted in the back view on the upper left corner of my screen..
the others will fade, if you could put that as an option that it can do automatic if turned on..
-Backview will get the vertices shown only which are processed by the screen. As the topview gets enlarged in size less vertices will be show on versa and
those will be processed and highlighted and the others will fade.
Achivements: 3ds max will become alot more easyer to use and others..
Link of image on imgur site showing the first part of main idea in process:http://imgur.com/a/X7fMx
File is attached too.
Idea 2:
Make plane vertices be able to combine, colapse option doesent work. Curently this doesent work too if i make a
car from parts and that is super easy way to build a car, but when i need to
combine later different planes i cant do it please fix this.
