Message 1 of 1
Select and Place bug?
when the tool "Select and Place" is active, then you can also select and place objects even if you are inside a subselection of an editable poly or mesh.
For me this feels like a bug and i often move objects around although I actually wanted to mark vertices.
It would also be nice if you can add an toogle for using the alignment.
If you press ALT the object keeps the current rotation. It would be nice if there is a toogle that the default keeps the current rotation and when pressing ALT it will align to the surface.
best regards,
Simon
