extrude modifier gizmo
rex_michael96TUB
Message 1 of 8
rex_michael96TUB
is there a way to disable the extrude gismo? it is such annoying to see it everytime i select an object with that modifier.
Replies (7)
Message 2 of 8
MartinBeh
I don't think you can directly disable the gizmo. Only switching a tab other than Create will hide the gizmo.
I checked whether it is possible to write a modifier in MAXScript that derives from Extrude modifer but does not show the gizmo. Unfortunately that seems not to be possible, you would need to write a full 3ds Max plugin using C++ for that.
The team was made aware of some users being unhappy with the new extrude gizmo but I cannot make any promises on whether or when this will be fixed.
Actually it would be generally a nice modifier option to be able to hide the gizmo...
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
Message 3 of 8
pyroskat
Shouldnt adding a mesh select modifier in top, make it disappear?  Would be good an option to hide it directly on the modifier, but this could be an easy solution for now.
Message 4 of 8
MartinBeh
Indeed! Great thinking! In fact, any other modifier that does not bring its own gizmo would do - for example Attribute Holder modifier to use something more lightweight.
Message 5 of 8
navya_gelli
Hello @rex_michael96TUB,
Have you had a chance to view the responses from MartinBeh and pyroskat and do they help resolve your query? If so, please mark the helpful response as the solution. If you're still experiencing issues, reply here and the community will be happy to assist further.
Navya | Community Manager
Message 6 of 8
rex_michael96TUB
Sorry for the late reply. thank you. its sad that it cannot be hidden for the meantime. it is just annoying. hopefully autodesk would remove it. its very unnecessary. thank you
Message 7 of 8
rex_michael96TUB
thats my temp solution. it is just irritating that everytime i use extrude that i have to put a edit poly oir mesh modifier.
Message 8 of 8
rex_michael96TUB
Apologies, just been busy. i guess i will just hope and pray that it will be removed soon.
