3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Select all objects with id
2 REPLIES 2
2589 Views, 2 Replies
Working with 3ds max imports from revit and it really doesnt let you group things so I set my objects all with the same id 54. Is there a easy way to reselect everything with id 54?
2 REPLIES 2
blakestone
I assume you're referring to the G-Buffer Object ID.
If so you can use the script below in the MAXScript Listener:
-- Click MAXScript > MAXScript Listener
-- Clear anything showing in the pink area and paste the below script in there
-- Highlight all the script in the pink area (because it executes only the selected lines) and press ENTER on the NUMPAD to execute.
This will deselect all objects in your scene and reselect all the objects with an ID of 54.
	clearselection()
	for o in objects where o.gbufferchannel == 54 do selectmore o
Technical 3D Graphic Artist
Autodesk 3dsMax 2015 - Service Pack 4
blakestone
visual example:
Technology Administrators
