Search 3ds max commands (X) crashes max
mikko_kovasiipi
mikko_kovasiipi
Hi
I don't know what has happened but the Search 3ds max commands (X) crashes my max. Doesn't matter if I press X or choose it from Help menu. After this started to happen I installed 3ds max updates and deleted the "ENU"-folder to reset factory settings, but neither of those helped. Any ideas why?
Mikko
mikko_kovasiipi
Anyone has any ideas why this happens? I re-installed max, but it didn't help.
Diffus3d
Does it work if you run 3dsmax as administrator?  Maybe it needs to generate a temp or list file and doesn't have permission?
A recent W11 update caused some problems in other areas, maybe this is related?
You can also check the 3dsmax log files for information about it.  If not thing shows the problem maybe with the OS or system, in which case the windows event viewer might show what caused the crash as well.
Best regards,
ads_decatae
Hello @mikko_kovasiipi ,
Try deleting this file: C:\Users\[username]\Autodesk\3ds Max 2025\User Settings\GlobalSearch.ini
Let us know if that helps.
mikko_kovasiipi
Yes! Thank you, it's working again!
guido77
Thank you! I was starting to panic until I found this answer 🙂
joaquim.moral
Hi @guido77!
I'm glad you were able to find a solution to your question.
Thank you as well for marking the correct answer as the accepted solution.
This way, it will be much easier to find and will help future users with similar questions.
We look forward to seeing you in the Community for any questions or doubts you might have in the future. Don’t forget to share your knowledge with others, or attend events to keep learning more 🙂
Thanks, and see you soon!
Your question got successfully answered? Then just click on the 'Mark as solution'
¿Te ha parecido útil este post? ¡Deja un like!
¿Tu pregunta ha sido solucionada? Selecciona 'Marcar como solución' y ayuda a las demás a encontrar fácilmente la información.
Joaquim Moral
Senior Community Manager
