3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Scene units settings not saved with scene?
3 REPLIES 3
office
525 Views, 3 Replies
I don't remember what this behaviour was in older versions since I just now started to change scene units more often but I found that in Max 2016 scene units settings are not stored with the scene. So often when I start rendering, I find that my cameras are zoomed in/out a bit or that some lights are very bright or dim. This is a real pain since I have to remember which scene was made in what units. Can someone else confirm?
I'm using Max 2016 SP1 EXT1.
3ds Max subscription customer since 2010
| Max 2022.1 | AMD Threadripper 3970X 32-core | 64GB RAM | Nvidia GeForce GTX 1080 Ti FE 11GB | NVMe SSD Samsung 960 Pro | Win10 Pro x64 | Nvidia Driver 466.47
3 REPLIES 3
Steve_Curley
in reply to: office
They absolutely ARE saved with the scene. Create 2 scenes which use different system units. Keep loading them alternately and you should get the Units Mismatch warning on every load, pretty much proof positive that the units ARE stored in the scenes. Unless, of course, you manually disabled that feature in the System Units Setup dialog (Respect System Units in Files).
Note. That setting is system wide - it is NOT saved with each scene.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
office
in reply to: Steve_Curley
Thanks, Steve, this fixed it! What I don't understand is why this option was turned off. I don't remember ever touching it. Oh well...
Steve_Curley
in reply to: office
It has always been on by default, as far as I can remember, in every release I've ever used. I can only assume either you (or someone with access to your system) turned it off - perhaps to see what it did - and never turned it back on.
Max 2016 (SP1/EXT1)
