Hi, how can I delete all the scene explorer in the red rectangle?
Thanks in advance
Solved by 10DSpace. Go to Solution.
The macroscript did not attach for some reason, so here it is again. You will need to unzip it first and then drag it into your max viewport. That will install the macroscript and it will appear in the list of actions that you can hotkey as "ClearLocalSceneExplorers"
