Scene Explorer custom attributes?
patrick8CTF6
patrick8CTF6
I'm trying to get more use out of the scene explorer (layer explorer), especially when setting up rendering passes. One common attribute is Object Properties> Visible to Camera. Very helpful for setting up renders for compositing, but this attribute is missing from 'Configure Columns' list. I can imagine many other attributes that would be helpful to have in the Layers panel. Does anyone know of a way to added other attrubutes/properties that are not found in the default list for 'Configure Columns'?
Only by using Maxscript,
go to this page and find: Adding Custom Property Filters
There is a example there as well, but you might better ask this in the Programming Section of the board.
patrick8CTF6
Thank you, this is very helpful.
