3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
saving problem
10 REPLIES 10
Message 1 of 11
47889 Views, 10 Replies
saving problem
hello guys, i have a funny problem these days...
when i save max (2020), no .max file is created and no error from max, i don't know what it means, i disabled anti virus, i checked preferences but nothing seem to help, any idea??? thanks.
10 REPLIES 10
Message 2 of 11
Daf
Maybe there is some confusion as to where it's saving. Try this. Use Save As instead and save to the desktop. Check and see if it saved the .max file there this time. If so then it may be that Max is actually saving the files, just not where you think they should be.
Another thought would be rights to folders and files. Have you tried to run Max as Administrator? Right click Max icon > Run as Adminstrator
Just for grins - check out this thread. May be something in there that helps.
https://forums.autodesk.com/t5/3ds-max-forum/can-t-save-project-due-to-backup-file-error/td-p/730386...
3DS Max 2020.3
i7-4790 @4GHz • 32GB • GTX 1080/8GB • Windows 7 Pro
Message 3 of 11
in reply to: Daf
thanks man for your answer, i solved the problem with brut force method meaning i uninstalled max then reinstalled it, the issue is fixed.
Message 4 of 11
jon.bell
Hi Hanzo,
Thanks for your update, and I'm glad the problem is fixed for you!
My feeling is that you may have changed your default \Scenes save location in 3ds Max (via the Customize >  Configure Project Paths menu). Resetting your 3ds Max preferences would fix this, but if you're still wondering about previous file locations, you might open a Windows Explorer menu and do a search on your PC for all .MAX files (*.max) just to confirm where they might've been saved.
Since you reported that this was fixed, if you don't mind I'll go ahead and mark this thread as Solved. If you have any other questions, please let us know. Thanks!
Jon A. Bell
Senior Technical Support Specialist, 3ds Max
Message 5 of 11
i am facing the same problem, i tried reinstall, but still not working....
anybody please help
Message 6 of 11
I have the same problem I can't even save selected objects
Message 7 of 11
POOJASAINI861
Hi.
I am using max 2020.
I tried lot's of time but my file is not saving.
I lost my entire project.😔
My max is not saving file.
Somebody please help.
Thanks 🙏
Message 8 of 11
You need to provide a little bit more info. Any error messages? Where are you trying to save the file?
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
Message 9 of 11
hey i'm facing the same problem, have you found any solution?
Message 10 of 11
No. Unfortunately no one has been able to help me. If you find the solution, please let me know.
Message 11 of 11
tomal799
in reply to: POOJASAINI861
facing same problem with 3dsmax 2020 , cant save anything
Technology Administrators
