3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Saving Max 2024 as 2022 - "edit poly operation" warning
1 REPLY 1
Alexx31
148 Views, 1 Reply
Alexx31
when I save my Max 2024 as 2022 I get a warning, which maybe means, that the edit poly modifier has changed.
In order to use the file (which has a lot of objects) I would like to know WHICH objects have an invalid usage of that modifier. Or what else I can do.
1 REPLY 1
RobH2
in reply to: Alexx31
RobH2
There's no way to know. What I do is just open the file in 2022 and look at objects to to see if anything is wrong. Then, fix it in 2022 if necessary.
One thing you can do if you know that you used 2024 to do a lot of specific edits using the new tools is finish that object and export it as an FBX or something. Then open the file and delete the object with the 2024 edit stack and import the FBX into your 2022 file.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
Rob Holmes
