I'm building a brick house which is yet to design and need many options to design it better and which should be very easy to change.
As you can see in Attachments that Via Morpher modifier and vol.select I can change the hollow section of the bricks by moving those box.
Is there any way to rotate those elements to any degrees the same as moving those box?
So if I move those box those bricks will rotate affected area and rest of the bricks will remain same.
Note: I need a Result as shown in the Screenshot.
Thank you,
