3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Reverting back to 2023.1
9 REPLIES 9
Message 1 of 10
fpatry
1493 Views, 9 Replies
Any quick way to revert back to 2023.1 without having to reinstall everything?
9 REPLIES 9
Message 2 of 10
in reply to: fpatry
nope
you have to uninstall everything
Message 3 of 10
DarrenP
in reply to: fpatry
no  the 2023.1 update replaces the 2023 install
so you can't uninstall just the update
you have to uninstall the entire program
DarrenP
Message 4 of 10
abrahamZZG2U
in reply to: DarrenP
I just uninstalled the whole program and then reinstalled 3ds Max 2023.1 from the product updates page of my autodesk account.
All my scripts, plugins, and custom UI was still there and working. So luckily only about a 20 minute exercise.
Message 5 of 10
fpatry
in reply to: abrahamZZG2U
Thanks Abraham, that's what i was hoping to avoid, but not that bad if only 20 minutes. Wating for a fix soon.
Message 6 of 10
fpatry
in reply to: fpatry
OK, for those of you who cannot wait for a patch, you can do what Abraham posted, just dont forget to use the custom install option and select 2023.1.
Message 7 of 10
Diffus3d
in reply to: fpatry
@fpatry I went ahead and marked your post as the solution for rolling back since you had the most detailed instructions for anyone else looking for this issue.  Thank you for posting it and thank you @abrahamZZG2U for your initial confirmation.
Best Regards,
Alfred (AJ) DeFlaminis
View Max Tips/Tricks Megathread
Message 8 of 10
pixelbox_sro
in reply to: fpatry
i am only gettgin preparing to instal black splash screen trying to do 2023.1 install
gets me nowhere....just sits there for  1 hour already
really well done!
Message 9 of 10
logan_foster_adsk
in reply to: fpatry
I am pleased to share that an update to 3ds Max, version 2023.2.2, is now available to download through the Autodesk Desktop App (ADA) or through the manage.autodesk.com download portal. This update resolves an issue with Chamfer operations in 3ds Max 2023.2 which resulted in the software entering an endless loop and becoming unresponsive either when loading files (locking up at 73% load) or when applying a Chamfer (through the Chamfer modifier, or Editable Poly or the Edit Poly modifier) to edges that connected to an open edge on your mesh data when using “Limit Effect”.
On behalf of the 3ds Max team I would like to thank everyone who took the time to share their scenes and report this issue to us, your help enabled us to quickly confirm and resolve the issue.
I would also like to take another opportunity to apologize for this issue. We are all as deeply disappointed as you are that this issue shipped with 2023.2, and we hope that with 2023.2.2, and future releases of 3ds Max, will resume the positive trend of releases that provided the stability, features, and functionality that assists you to create expressive content and share creative experiences in your work.
Logan Foster
Product Owner at Autodesk for 3ds Max
Message 10 of 10
yannverbeke
in reply to: fpatry
Hi, the loading issue is still there in 2023.2.2
Loading freezes at 73% on projects I try to open.
Please this is becoming a nightmare. I'm losing jobs because of this issue. I uninstalled Max already 3 times the past week. Please help me out.
