Hi there,
Thanks again for helping out with this...
1 - I have merged the scene into a new one.
2 - Could not access the Arnold Imagers as for some reason the Arnold Render View tab is not in my Arnold Menu drop down? I updated Arnold to the latest version but this is still the case.
3 - I applied an HDRI map to a Skydome light and applied 5 portal lights to the windows.
4 - I currently can't would delete some walls without loosing the parts that appear in the shot but I can use the animation to 140 sec to partially open the door. so more light gets inside.
If you could do a setup that we know works for you then I can see if the problem is my mac book not coping with the job. I am in a position to get a 32MB i9 core ASUS machine if you think it's necessary.
5 - Will look into samples re the interior and skydome as I'm not familiar with this term.
6 - Ditto TX textures and Auto-Convert Textures - will watch the vid now.
Updated version of the file is in the same drop box folder for you in the event that you can get it working and share back.
https://www.dropbox.com/sh/6kzk4rstghzg9lt/AADjwDbXtZAA-dRQllxJXgcRa?dl=0
Re your question, Looking the system info below the bottom right corner of the viewport(s) I gives a render time of 20 secs. This may be that the render has finished after 20 secs or the render has not yet started, as far as I can see there is not way to discern this. How long did it take your machine to render the image? This will give me some idea of how long to leave the black screen before concluding that the render has completed.
very best
Luke
many thanks
