Rendering problems Vray
Hello, I trying to render an image of a character, but I don't now what is the problem because I see this:
And the real image, has to be something like this
I need help beacuse I don't understand about settings of Vray.
Thanks to everybody who read this, I really hope you can help me.
Hello Imanol Noseda,
The problem seems to be from the material conflicts of VRay version
Could you Attach the max file to try fix it for you
Best Regards;
Fadi Al-Qurainy
Senior 3d Artist
Hi, i suspect a bad configuration of the exposure control.
Here a nice video with a lot of explanations about Vray exposure control.
https://www.youtube.com/watch?v=Xq68FNd1YQ4
Of course, could be something else, but it's a good place to start.
Thanks for your help, when i open de character, this appears:
This message means your scene is looking for 2 textures. You can click on continue, but your scene will probably miss 2 textures.
Or, in 3ds Max, click on the 3 in top left corner, References, Asset Tracking and make sure the path to those files is correct. Change the path until 3ds Max say he found those files.
Also make sure your project is set correctly: https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/3DSMa...
