render time
render time
semsema4
render time
semsema4
i have a file to render it was fine for test render but when i tried to change render settings for final render it take more than 10 hours to render and the file is simple i don't know what i did wrong
miledrizk
There is not enough info to guess what's the problem,
First, what rendering engine you're using?
Also, info about the render setups in the different tabs,
The type of materials, their subdivision values, etc,...
[email protected]
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
Richard.Vivanco
Put an screenshot of your scene and some information about your pc (ram, cpu)
Richard Vivanco V.
Arq. BIM Manager + Autodesk Certified Instructor
Youtube | LinkedIn
autodesk 3DS pro
semsema4
this is my computer details
semsema4
3dmax2017
vray3.6
miledrizk
Well, the only value that I see a bit exaggerated is the Subdivs in the Irradiance Map,
Try a value of 50
Another thing, if you're using Displacement maps in your material editor,
Try using the VrayDisplacementMod instead with the 2D Mapping option checked.
There might be different reasons related to the materials or other stuff,
But for now, try the above and see if it makes some difference.
Also, when possible, you need a better computer with a faster CPU and more Ram,
Especially a faster CPU, since most of the rendering work happens on the CPU level.
I guess you're using a laptop, and if that's the case the cooling systems in Laptops are not
That good, and when the processor becomes overheated it loses a significant amount of its performance,
The CPU tries to protect itself from damage by reducing its speed.
[email protected]
semsema4
this is the render
the light
the material in the scene
can i improve it a bit with low settings
also i couldnot get render elements i donot know the problem
i am not good with post production though
