Render Setup Window Missing
Message 1 of 16
Hi, hopefully someone can help me. I'm working with Autodesk 3ds Max 2009.
I have obviously done something and the Render Setup Window has disapeared and I can’t get it back.
Although i can press the buttom (tea cup) and it shows "active", the window does not appear anywhere near, what leads me to believe i've managed to “float” it and drag it offscreen.
Does anyone have any clue as to where it may be hiding or how I can get it back?
Many thanks in advance.
Replies (15)
Message 2 of 16
If it has gone off the screen, you can change it in the 3dsmax.ini file.
Find it here:-
C:\Documents and Settings\username\Local Settings\Application Data\Autodesk\3dsmax\2009 - XXbit\enu
Message 3 of 16
thank you very much samab!
it worked perfectly! (although i had some problems finding the file)
Message 4 of 16
I had the same problem with the material editor and in case anybody else does, the path in vista is: Username ► AppData* ► Local ► Autodesk ► 3dsMax ► YEAR - ??bit ► enu ► 3dsmax.ini
*folder is hidden, you will need to go to control panel and change the settings before you can get to the file.
Message 5 of 16
A quicker way (usually) is this...with render setup window active (eg unpress and then repress the button):
- press Alt + Spacebar
- press M
- use arrow keys to move the dialog into view
Message 6 of 16
Hello, my 3DMax  Rednder Setup Dialogue is missing, I hace tried all tips possible and the panel don´t show any more... any tip. Please. Thanks in advance
Message 7 of 16
...it Works perfect, thk alot...
Find it here:-
Message 8 of 16
Press Alt+Space then M to (m)ove the windows with the cursor keys or the mouse(works with all windows in Windows).
Message 9 of 16
Nice!! It worked for me! Thank you!
Message 10 of 16
Oh hell yeah. Thanks
- press M
Message 11 of 16
Thanks !!! 😉
Message 12 of 16
philip
Then what do you change in the INI file?
Message 13 of 16
ramiB6DQB
Observer
Observer
You are really genius this simple method solve it because I was using 2 monitors and after removing one and the windows is disappeared on the other monitor I removed but this method is really great!
Message 14 of 16
hi i have win8 and it doesn't work.
I did like this:
1. click the "render configuration" pod icon
2. Alt + space and I see the bar only with tree options: restore, move and close
3. After clicking the restore - small bar disappeared
please help me
i saw second option with backup file but i'm completely confused - don`t know what should i change in this notepad.
Message 15 of 16
Using 2016, just went to the address showned up here and removed the "ini" file.
When reopened and click Render setup incon, it had appeared.
New "ini" file has also been created
Ticket solved for me.
Thanks a lot @Anonymous and everyone
Message 16 of 16
New "ini" file has also been created in place.
