Render Elements causes a crash when I try to add a pass
Message 1 of 43
Hi Everyone.
This started recently, it might be the addition of Deadline but though I would check in here before going to their forum.
Render Elements causes a crash when I try to add a pass, doesn't matter which render engine I try. Just started a few days ago.
Might have coincided with our company testing Deadline.
Thanks ahead of time
Mike K
Accepted solutions (4)
Replies (42)
Message 2 of 43
me too, windows 10, 3ds max Design 2014(2015)
Message 3 of 43
My too, 3dsmax Design 2014 (2015), windows 10.
Only with 2016 all fine.
Message 4 of 43
z8er
Observer
Observer
I am also having this same problem.
3dsMax 2014
Windows 10
Max on a seperate machine with Win10 works fine! 😐
Message 5 of 43
ronav
Observer
Observer
I have the same problem with windows 10 and 3ds Max 2014. I hope they solve the problem as soon as possible
Message 6 of 43
Mike did you find any solution to this problem ?
Message 7 of 43
This just bit us hard. From out of nowhere it seems, one of our artists started getting this crash today.
Running 3ds max 2015 and Windows 10 x64.
The only thing we did yesterday was installed Wacom drivers. So we uninstalled them again and max is working as it should again.
Crappy Wacom drivers does it again I guess.
Message 8 of 43
I had the First beta installed. Removed it and the crash went away.
Message 9 of 43
Jens thank you so much I was on the verge on reinstalling max I uninstalled the wacom driver although I didnt update it recently and it worked perfectly, thanks again.
Message 10 of 43
z8er
Observer
Observer
Stinking Wacom! Updating drivers hasn't worked yet, but unplugging does... Thanks!
Message 11 of 43
mdmowry
Same Wacom troubles here - crashes each time until the Cintiq monitor is turned off. Worked fine pre-upgrade to Windows10 under Windows8.1 though.
Message 12 of 43
harumscarum
Same problem here
maybe another SP for 2014 can solve it since no such problem on 2016?
does anybody tried to contact Wacom to resolve?
Message 13 of 43
Yeah I have repported it to Wacom and they are working on it with Autodesk. I've sent them crashdumps and helping them in every way I can. I sent them the link to this thread as well.
Message 14 of 43
Is there any fix for this, it's an absolute nightmare?
Message 15 of 43
Wacom has investigated and came to the conclusion that it's a 3ds Max bug so Wacom won't fix it. Autodesk has to fix it in a new SP (which will probably never happen)
Message 16 of 43
I have the same problem but I don't have a Wacom and never had... has anyone discovered another solution?
I´m running 3ds max 2015 and Windows 10 x64 too.
Message 17 of 43
harumscarum
you probably have laptop with touchscreen
Message 18 of 43
You are right!! I've disabled touchscreen and it works perfectly. Thanks a lot!
Message 19 of 43
I had this same issue, except I do not have a Wacom, or a tablet PC. I was able to resolve it by going to the task manager, and closing the "Touch Keyboard and Handwriting Panel" task. Hope this helps!
Message 20 of 43
mdmowry
Great solution! works for me, and it is apparently not a wacom issue at all.
thank you for sharing!
