Relative path creation bug?
meYZUGU
Observer Observer
meYZUGU
Observer
Observer
Hi, I'm an IT admin trying to help a colleage with a Max issue, hopefully someone on here can help!
We're re-organising our file storage, and to help make projects portable between different staff we want to use relative paths in asset manager, however Max seems to be creating very inneficient paths which won't work across devices.
We have our .max file in a project folder, and then for example 'models' folder within the same folder containing model files. I would expect the relative path to generate simply 'models/filename' but instead we get '../../../../../all the way back to the drive root/subfolder/subfolder/subfolder/models/file'. If we manually edit the path in Max it respects the correct path and finds the assetts, however this will take a long time! Is it possible that we've missed something in the config and we can correct this behaviour?
darawork
There is a very good plugin for handling all aspects of 3DSMax scene files here: https://www.pixamoon.com/product-page/library-track-relink
Perhaps it might be handy in your case? Seems very comprehensive.
Darawork
AutoDesk User
Windows 11, 3DS Max 2026, Revit 2026, AutoCad 2026, Dell Precision 7875 nVidia - Quadro RTX4000 ATA - AMD Ryzen Threadripper PRO 7965WX 24-Cores - 128GB RAM
meYZUGU
Observer
Observer
Thanks, I will have a look at that software. Does this behaviour not constitute a bug however? While it is possible to overcome by paying for extra third party software it would be better for the core product to simply generate an efficient relative path?
Morne3D
So does all staff not have access to the same mapped network paths?
Why can you not simply use absolute paths? Are some staff in a different location?
meYZUGU
Observer
Observer
Hi, thanks for your reply and concern, however the issue here is the software not producing an efficient relative path, rather than a teardown of business practices 🙂
