reflection
reflection
reflection
Hi!
I expect to see the reflection on the second sphere, but it doesn't work this way.
What do I miss?
Thank you in advance!
10DSpace
As explained in the autodesk docs flat mirror only works for coplanar surfaces (i.e., completly flat,  not a sphere)
https://docs.autodesk.com/3DSMAX/15/ENU/3ds-Max-Help/index.html?url=files/GUID-129B1FFB-B00A-4C39-9B...
Here is a short video explaining how to use the flat mirror map with the top polygon of a box (set to material ID 1) as the flat surface.
https://www.youtube.com/watch?v=nP2ivhAEjOw
Hope this clears it up for you.
thank you!
