Reference image to 3D Model
Message 1 of 8
Hello Everyone,
  I want to import 2D bitmap images into 3Ds Max and convert it into 3D Model for animation. How can I do that?
Thanks in advance!
Replies (7)
Message 2 of 8
is this what your trying to do: https://blogs.autodesk.com/recap/introducing-recap-photo/
have you used 3ds max before?
if not this is something very advanced you need to learn the basics 1st
Message 3 of 8
  I used that I know thank you. No, actually I want to learn how to make a 3D model with a 2D bitmap image. I mean it could be images that I can get from the web as well.
Message 4 of 8
irishman_team_kilber
there are tons of tutorials out there it all depends on what you are thinking of modeling, most artist use 2d images for example architectural design cad/floorplans, weapons modeling, character modeling etc,
i would start off with the 3ds max tutotials if you have not already done them. are you gonna make this a career or is it just a hobbie?
Message 5 of 8
hagen.deloss
Hi @Anonymous
I agree with @Anonymous and @irishman_team_kilber that there is a learning curve with 3ds Max, but I would also note that it depends on the end result.
For example, you can get a pretty good topographical height map by using the displace modifier in 3ds Max, here is more information about that. It pretty much takes a black and white image, and calculates mesh height based off the image. Like this below image.
*Note: this works best with greyscale images, and complex mesh that needs certain, deformable/animated mesh would need to be hand modeled.
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Message 6 of 8
hagen.deloss
@Anonymous
Any thoughts on previous comments? It would be helpful if you had time to give an update, that way other Community Members can benefit from your process 😄
Please select the Accept as Solution button if a post solves your issue or answers your question.
Hagen Deloss
Message 7 of 8
   So here is the question. I wanted to make a 3D Model of a luggage and the designer I hired asked me to take pictures from all directions and above/below of it. From those images he has created a 3D Model of the luggage. Because of the language barrier he couldn't explain my how he did it and by the time we lost contact. I would like to learn the methods that he used.
Message 8 of 8
hagen.deloss
Hello @Anonymous
Great to hear from you again!
I would recommend checking out some basic 3d Modeling videos, here is one to get you started 😄
To model from a reference image, you can follow the process outlined in this video here.
I hope this helps!
Hagen Deloss
