real time expression float
Hello.Is there any why for when we want to use S or NT or any other function in expression float you should run the time line, is there any way to change it to real time.
You want to execute a script over time without moving the timeline, by pressing the Play Animation button?
I am not sure such thing exist, but you could try to execute a script on mouse movement. Take a look here, under events.
Also, why not run the timeline? If your script assumes relative values you could run stuff in a timeline loop continuously. $box001.position.x += 1 will forever move the box 1 unit, every frame, no matter where you are on the timeline, no matter how many times the timeline loops.
Thanks.I want a real time result, like a game engine. Any way?
