"SetDir #autoback new_path" will be ignored?!?
jens.diemer
jens.diemer
I changed the auto backup path with:
		bak_path = pathConfig.appendPath maxFilePath "max_autobak"
		format "Set #autoback to %\n" bak_path
		ok = makeDir bak_path all:false
		if (ok == true) then (
			SetDir #autoback bak_path
		) else (
			format "Error: Can't create or already exist path %\n" bak_path
But the changed directory will be ignored and the origin project path will be used.
How to fix this?
Jens
https://github.com/jedie/3dsmax_bugs | https://github.com/jedie/3dsmax_patches
BenBisares
Autodesk Support
Autodesk Support
Just wanted to get some background information just so I can make a better informed response. Why are you trying to change the autobak location using scripting rather than though the UI? (Customize > Configure User Paths… > File I/O > AutoBackup)
Ben Bisares
jens.diemer
Have you seen: bak_path = pathConfig.appendPath maxFilePath "max_autobak" ??
Jens
BenBisares
Autodesk Support
Autodesk Support
Understood, just wanted some background in case I had an alternative method in mind.
I'm in the middle of testing things out and analysing what's going on. I'll keep you updated with the results.
Ben Bisares
jens.diemer
I seen that chang autoback will "break" the maxscript plugin "Copitor" 😞 Because it stores the copy&paste content files into autoback... So it can't copy&paste between scenes in different paths 😞
So i will deactivate it...
EDIT: btw: Copy and Paste between Max instances is a wish from 2010: http://3dsmaxfeedback.autodesk.com/forums/76763-small-feature-requests/suggestions/1103695-copy-and-...
Jens
