Announcements
"amp;" is showing everywhere
Message 2 of 8
anyone has any idea why is this happening?
the word "amp;" appeared before some of the words in 3ds max everywhere.Capture.JPG
Replies (7)
Message 1 of 8
Swordslayer
I sort of have an idea why, though not sure about the idea how to fix it. Usually, the ampersand (&) precedes a menuitem letter that works as a shortcut (and that letter is often rendered with an underline to show that). In html, that's escaped as & and that's also how they are saved in the .mnux file:
customTitle="&Create"
Could it be possible that they were double-escaped, resulting in '&Create' ? Could you check the .mnux file? Or replace it with the same file from another working install?
Message 3 of 8
Alfred.DeFlaminis
Hello @Anonymous,
@Swordslayer has an excellent post here and I wanted to ask you, did you recently install something which caused this to occur?  You can always reset your user settings and that should remake all your menus and interface items.  Can you please try that for me?
Best Regards,
Message 4 of 8
Alfred.DeFlaminis
Hello @Anonymous,
I just wanted to follow up here, any progress on this issue?
Best Regards,
Message 5 of 8
@Alfred.DeFlaminis wrote:
Hello @Anonymous,
Best Regards,
Currently waiting for my MIS team to assist on that. Will try both ways suggested here and update on the result. Thanks btw!!
Message 6 of 8
Alfred.DeFlaminis
Hello @Anonymous,
No problem at all, I'll do anything I can to help you, always!  Happy New Year!
Best Regards,
Message 7 of 8
Hello @Anonymous,
Best Regards,
Issue solved with this post here! Thanks alot!
Message 8 of 8
Alfred.DeFlaminis
Thank you for the confirmation @Anonymous and Happy New Year!
Best Regards,
