I'm just circling back around to say my RTX is still thrilling me.
No regrets now in over 6-months. In fact, I received a private message from a user who asked of the RTX could eliminate their need for using a Render Farm. While the answer to that question is not quite that simple I did offer my opinion and some actual benchmark tests I've run using both the RTX 2080Ti and the K5200. I'll post that response below as well at the tests. Note: the tests file link will expire on 11/6/19. So anyone who finds this thread after that date won't have access to the link but I've attached that same file to this post.
-------------------BEGIN PASTE-----------------
I have some data for you. I did a lot of tests before buying the GeForce card. I've always (for 23 years now) used the NVidia Professional or Quadro cards. I've never been really impressed with them and they've always been very expensive. So this was a scary switch for me. However, I'm glad I did it.
I've attached some tests. I've always tested my systems over the years and I save the tests so I can compare them to see if I'm running fast. Sometimes my machines feel slow and by running a test I can tell if it's just me or if it really is slow. Usually, the test shows that the machine is fine and it's just me. So I ran tests before I bought the RTX. I 've included those.
The tests with the most recent date are the RTX 2080Ti and the older test, Feb and March I believe, are the K5200. I tested with two different programs. I like a 2nd opinion I guess. You can go to the GPU or Graphics areas and see the significant speed increases. For some reason, DirectX10 got a lower score in one test but in all others, the RTX blows the K5200 away. If I had run the test again the DirectX10 would have probably improved as that low score is probably a momentary glitch. And, my overall machine scores improved.
I can't tell you that you can eliminate a Render Farm or not. It's not that simple. The RTX only speeds up GPU rendering. A lot of my work needs CPU rendering because the GPU doesn't support every one of V-Ray's features. The RTX won't make your CPU renders any faster. I always use a Render Farm these days because if a frame takes 8-minutes to render and I have 1200 frames, that's 160 hours on my machine. That's about an hour on a farm using 100's of machines.
What I can tell you is that you'll get faster IPR/GPU previews on your machine than you did. And, if you do render your work with GPUs, it will be about 2x-3x faster than it is with the K5200. Again, will that eliminate a Render Farm, it depends on how much time you have and how many frames? If the K5200 renders 900 frames overnight in 8 hours, then I'd guess the RTX will render those 900 frames in 3 hours. So it will save you time. But, no amount of GPU or RTX or whatever can eliminate a Render Farm when you have a large project.
I have a Dual Xeon machine with E5-2650 V3 processors. So I have 40 CPU render threads. My machine is much faster than most Render Farm's CPU renders. But the power of the Render Farm is not "one" machine, it's that there are 1000s of them. That's the power of the Render Farm. So I say that no graphics card, RTX or otherwise, will eliminate a Render Farm. But what it will do is speed up what you are currently doing. Then you can decide. If your normal project with the K5200 takes 24 hours to render, then maybe the RTX will render it in half that time. There is probably a level where you can't have your machine tied up for so many hours rendering. Mine is 10 hours. If I can't render in 10 hours overnight or less, it goes to a farm. So on some level it can eliminate a Render Farm. Say the K5200 would take 20 hours to render. That would be Render Farm for me. And then consider that the RTX might render that same scene in 10 hours. Well then, the farm isn't necessary as it's now under my 10-hour cutoff, so in effect, I've eliminated the farm for that case.
Anyway, I hope this helps. I have had the card over 6-months now and have never looked back. I still have my K5200 in a box knowing I could put it back in if the RTX ever let me down. To be honest, I don't think that expensive K5200 will ever go into a machine again. Want to buy it...lol....?
I hope this helps.
Rob
Here a link to the tests in a .zip file: (it will expire in 7 days)
https://drive.google.com/file/d/1i8wnHQBeuJUuORMk4tg4ECPbvJvILM_v/view?usp=sharing
Rob Holmes
3ds Max (2023-2026), V-Ray 7, Ryzen 9 9950X3D Processor, DDR5 128MB, Gigabyte Aorus X870E Master motherboard, Sabrent Rocket NVMe Gen5 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
