Hello @dacosdesign
Thanks for posting your question to the forums! Hmmm, that sounds frustrating, I hope I can help you work through this issue.
What version of 3DS Max are you using?
When you say "out of position", what do you mean? do the xref objects snap back to world space zero?
I would suggest bringing in all your objects into a fresh scene and seeing if that helps. I just tested Xref in 2019.1 and couldn't reproduce. Here are the steps I took to try to emulate your environment.
- I loaded a blank scene
- I went to file>reference>Xref Objects and brought in 2 models
- I saved my scene
- I loaded up one of the externally referenced scenes and made some new objects, and then saved ( I made sure to note their coordinates)
- I loaded up my scene with the Xref objects and noted the location of the new objects where the same.
If there is anything I left out on how to reproduce this issue, let me know! It may be the version of 3DS Max is different 😄 I can test on older versions just lemme know! Talk to you soon
